getting adjusible spring plates for the rear soon, after dubfreeze but it WILL be the lowest van (not on hydros...etc) at bus types.... hjobs to do before Dubfreeze.... rear brace bar rasie gearshifter raise and possible transmission/engine raise allot of work.... proberbly easier to make a sump plate... ive already got a trekker sump gard to go on when the rearbrace bar rasie is done thats the only bit which touches the floor!!! then the next lowest thing on its the front gear linkage rod, which is routed underneath the beam... soon to run 4 UV joints to go thu the beam... rasied the centre pin on the K&L pin beam 2" you see.... it wont go over the top as the beam is up to the floor so much ive had to solot the floor to acept the adjusters.... so it has to go thu the side.....lol
it'll be at dubreeze if you wanna check it over....
cheers alex
