Bigbear
The pic of headlining looks like it has lines in it, but when it's fitted you can't notice really.
Cheers blue! It's getting there slowly (ain't they all?)creationblue said:Great looking Westy 8)
Cheers mate, it was in desperate need of a spruce up. Once it's all refitted and cleaned etc I can start making it a bit more cosy, with cushions and bits and bobs.Lee C said:Looking nice in there noo mind!!
benveedub said:wow some amazing polishing going on there!!!
looks amazing 8)
Do ou mean the trim that goes around the pop top opening to tidy up the headlining edge?mike202 said:lovely shiney polished bits of trim you've got there
Looks like you've fitted the westy hatch trim -the plastic strip around the metal - did you fit it all in one piece and did you encounter any difficulties? I had to use a bit of glue with mine and its still not great, its coming away at the corners.
Bigbear said:benveedub said:wow some amazing polishing going on there!!!
looks amazing 8)
Cheers dude, I got myself a polishing kit from eBay it only cost £12.99 which is greàt value for money when you look at the results. It just goes in the end of a drill , you have a cutting compound and a polishing compound, and roughly 20 felt heads. The more effort you put into the cutting the better the result of polishing.
