Bigbear
This is this polishing kit I used, roughly £14 with postage.simo said:Bigbear said:benveedub said:wow some amazing polishing going on there!!!
looks amazing 8)
Cheers dude, I got myself a polishing kit from eBay it only cost £12.99 which is greàt value for money when you look at the results. It just goes in the end of a drill , you have a cutting compound and a polishing compound, and roughly 20 felt heads. The more effort you put into the cutting the better the result of polishing.
Top work there fella 8)
Do you have a link for the polishing kit you used, also where did you get the rattle cans used for the floor?
Lastly (sorry :mrgreen: ) when you refitted the T trims around table did you glue them in or are they tight enough?
Keep up the good work 8)
This is the paint I used, also from eBay. £20 free delivery. You will need to buy lacquer with it (I didn't bother as it was just the floor)
The T trim just pushed back in mate, it still perfectly tight, in fact you have to knock it in with a hammer.
Don't know how to post links using I phone, sorry.
Il post the item numbers if you need them?
