So as some of you will know I recently dropped the engine out of my van with the watchful eye of MEB's Dave.. All went surprisingly well and the new crankseal is holding well we replaced so far!!
Having had the support and chance to get down & dirty *cough* :lol: It's spurred me on to start doing a few bits myself. Well that and the fact that the garage bills are just getting silly! :roll:
So I've started this thread in the hope that you engine guru's will follow me in my clumsiness and findings and be able to offer advice on the way.
The main reason is to fit the 36mm twin dellorto's, but already I'm findin stuff on the way that I know needs attention. So long as I can get the Dell's functioning I'm happy to get it to the rolling road afterwards. All that tuning lark is for the experts. But you never know, I might get them running well yet Worth a shot and keeps me busy..
So, this afternoon I started with this..
Mainly because I want to fit these
And ended up here :? :shock:
Questions:
Should the fan shroud be secure.. I found mine was lifting up without any problems, or does it just slide on?
The oil filler neck wasit started pissing out mayonnaise from
a rubber bung that had split underneath! Is this normal?
How frikken hard is it to get the dynamo off???! :x Need to replace it with one I've refurbed, so that came off!
When I was battling with the dynamo the belt was slipping, is this normal?
I found, two broken spark plug casings, I'm not sure how much relevance that will have on the running but I'll replace them anyway.
Is it possible to get the tinware off the top of the heads without dropping the engine? Just could do with a tidy up that's all. No biggy if not.
What size fuel pipe do you need for the twin carbs pls. There's such a selection 6,7,8,10mm??
I'm sorry if this is all simple stuff but it's new to me & pretty much everything I've learnt is from this forum! Really grateful for your help guru's :mrgreen:
Questions:
