pablodog said:should add just over 2 cm to the sidewall so just over 4 cm in total. Should squeeze that in easily and fill the `gap`a bit. Tyres ordered and on there way anyway............
Bluesnailman said:Hi. I'd be interested as to how these turn out also. When I did a bit of research some time ago I think I came to the conclusion that I needed a wider wheel rim as my 4" wide 14s would be undersized. My idea was to fit larger tyres at same time as giving the engine a bit more grunt. Would give me slightly higher gearing....
Sent from my moto g(7) plus using Tapatalk
No, I wonder if my memory is letting me down.... Did they need to be 5inch? Who knows...sparkywig said:Bluesnailman said:Hi. I'd be interested as to how these turn out also. When I did a bit of research some time ago I think I came to the conclusion that I needed a wider wheel rim as my 4" wide 14s would be undersized. My idea was to fit larger tyres at same time as giving the engine a bit more grunt. Would give me slightly higher gearing....
Are you running Beetle steels?
Nice!! What's the road noise like with them on?pablodog said:
Bluesnailman said:Nice!! What's the road noise like with them on?pablodog said:
And Ozziedog normally the provider of sound advice....ozziedog said:Bluesnailman said:Nice!! What's the road noise like with them on?pablodog said:
We’re in an ancient Volkswagen, so what’s another bit of noise [emoji38]
Ozziedog,,,,,,, noise??? I don’t believe you asked that [emoji38] [emoji38] [emoji38]
