popcorn balls
Just cleaned mine up - decades of gunge :shock:
What is the correct fill level of oil? there's no fill line or anything - but there is a sloping ridge thing about an inch up from the bottom, i've filled it to the bottom of this ridge, is this correct?
Also the bottom of the air inlets isn't connected to anything - i gather it connects through the tinware to the exhaust? i've got a non standard exhaust which it won't connect to, so what do i do with it?
Thirdly what's the little plunger thing attached to a spring - looks like it opens the top flap at a certain temperature?
Lastly, the thing that connects the filter to the carb is split, i've taped it up, but has anyone got a good one they don't need?
Chris
Chris
