K@rlos said:Is it a stock engine? If so you DO NOT need additional breathing. If it’s breathing heavy then issues lay else where.
atafonso said:Do you have only that hose coming off the fuel pump hole as a breather or is there any more vents? That is not enough even for a stock engine, the ID of that fitting is only 10mm. You need at least 16mm ID(the late stock breather is) or else it will leak oil from the pulley and other places.
Abel
atafonso said:I knew you would have done it properly
