oil problems
burt
Feb 22, 2009
224
Hi AGAIN iv noticed after my trip down to devon there is like an oil residue and oil spots covering the whole of the back of our van does any one no why this is
If you are sure its oil then have a look under the engine. It's possible there is a minor leak and turbulence is throwing it up onto the rear as you drive.
Hello
I had a similar problem last year
Traced it down (eventually )to a hole in one of the push rod tubes
Norm :D
Found an oil leak i belive its where the gear box goes in to the engine :cry: does this mean its an engine out job
If your sure thats where its coming from then yes unfortunately.
Best to double check though - by thoroughly cleaning the underside and taking a short test drive - to check exactly where it's leaking from.
