I do and that was what I was going to try nexthave you got a screw extractor set? They are sometimes useful.
Yep - had a few successes doing it this way (and one or two failures) - if the extractor fails then I will have to resort to this next!Hold the nut onto the bolt and weld through the nut.
Thanks for the reply. I went to the Llyn Peninsula a few years back and had the problem re: finding gears. I’d hit a hill, jump down gears and struggled to house the intended 2nd or 1st. Going up and down gears was frustrating. I remember double clutching at one point with the tiniest success. I’d try anything to be honest. Then? I bought a quick shift kit, which Paul (the Guru) fitted and haven’t looked back since. It’s an amazing difference. Sparkywig has amazing advice though. More knowledge and experience. Oh! I do remember the guy in a local garage put mine on back to front once way back when. That was spooky! So pleased though that you are out there despite the niggles. Took my bus to the beach yesterday with my visiting daughter and four grandkids. As said, I’ve retired now so have a much freer life opportunity wise. You’ll love the freedom your bus will bring. Nice to see all the benefits of your hard work.Thanks and yes, had a few trips in her so far.
My daughter was up this weekend so I said to her lets go for a spin in the bus - engine fired first time (after 3 weeks of not being fired up) which was good but could I get it in gear - nope
Will not go into 1st to 4th at all and when I try reverse with the clutch down it grind the gears so not sure what has gone wrong????
Cheers Si - will have a look when I get a chance and report backTry adjusting the shift plate under the gear stick.
Put it into 2nd gear, slightly loosen the two bolts holding the base of the gearshift and move the gearstick so that the bottom bit is vertical and the cranked bit is at 30 degrees to the rear of the van. Then move the shift plate as far left as possible without moving the gearstick. Tighten the two bolts. This should help selection of 1st and 2nd.
If the lever doesn't travel straight forward and back in the 1st/2nd plane, try slightly twisting the shift plate.
Retired - well done and enjoyThanks for the reply. I went to the Llyn Peninsula a few years back and had the problem re: finding gears. I’d hit a hill, jump down gears and struggled to house the intended 2nd or 1st. Going up and down gears was frustrating. I remember double clutching at one point with the tiniest success. I’d try anything to be honest. Then? I bought a quick shift kit, which Paul (the Guru) fitted and haven’t looked back since. It’s an amazing difference. Sparkywig has amazing advice though. More knowledge and experience. Oh! I do remember the guy in a local garage put mine on back to front once way back when. That was spooky! So pleased though that you are out there despite the niggles. Took my bus to the beach yesterday with my visiting daughter and four grandkids. As said, I’ve retired now so have a much freer life opportunity wise. You’ll love the freedom your bus will bring. Nice to see all the benefits of your hard work.![]()
The gear linkage underneath butting up to the metal (when in 2nd gear):
Still balks a bit going into gear but it does now - still crashes the gears when trying reverse though!!
Been using the ointment and helps a little. Hospital rang today and my appointment is Friday so a long wait.Ouch!
I've had a bit experience with metal shards, hope it gets better soon.
Cheers - feels a lot better today, bright lights are not troubling it so hoping it is sorting itself out and the trip on Friday will be for nothing!!Get well soon, Andy!
Glad your eye is healing. Must have been worrying. Gardening is definitely a great alternative relaxation option. I just took a good friend to see an ophthalmologist consultant re: her eye problematics. Listening to outcomes, you realise how important it is to keep them as safe as possible. Pleased you are on the mend. And pleased you are very much on the cusp of a jump in the VeeDub......getting out there ......and enjoying the summer relaxation experience. All the best. You deserve it.Went to the hospital yesterday and they pulled out more metal, it was quite deep into the eye he said.
Last night I was in agony - could not watch the TV or work on my laptop so at 9pm went to bed.
Today, the eye is OK and not giving me much issues - been given orders to keep away from the van by the missus so will do some gardening instead (and listen to a few tunes on the HiFi)
Should be all good![]()
Thanks for your kind words.Glad your eye is healing. Must have been worrying. Gardening is definitely a great alternative relaxation option. I just took a good friend to see an ophthalmologist consultant re: her eye problematics. Listening to outcomes, you realise how important it is to keep them as safe as possible. Pleased you are on the mend. And pleased you are very much on the cusp of a jump in the VeeDub......getting out there ......and enjoying the summer relaxation experience. All the best. You deserve it.![]()
Register today and take advantage of membership benefits.
