Everything apart from the the drums are new - the star adjusters move easily so no need to clean up.That drum has definitely had it. The inside should be smooth with no grooves in it to ensure maximum contact area with the shoe when braking. Grooves are caused by worn out shoes usually, used to happen a lot when brake linings were riveted on in the good old days. Ideally you should replace drums in pairs to ensure brake balance and new shoes as well if they are grooved badly, otherwise they will wear your new drums unevenly. If its minimum damage to shoes you could smooth them back with Emery Cloth but wear a mask while doing it. And as gvee says adjustment is key, good idea to clean up the threads on the adjusters while the drums and shoes are off, should save some swearing later![]()
Thanks.A moderately successful first drive then.
The horn cable should be a ground, the 12V feed goes to the horn and then the ground is run from the horn to the steering coupler and up the column to the horn push.
Hold the nut onto the bolt and weld through the nut.The bolt is a bit sunken. I will grab some new metal drill bits and work them through then see if I can get it out that way.
Register today and take advantage of membership benefits.
