Haveacamper
- Joined
- Oct 2, 2007
- Messages
- 2,068
- Reaction score
- 3
OK, so I was just about to "TRY" and raise my bus slightly knowing that its a nightmare.
I jacked the bus up and managed to get my adjusters off. I then proceeded to jump up and down on one of the wheels to see if i could rotate the trailing arms. Not to my surprise, nothing happened.
My new optimism did mean that it didnt stop me from looking to see if the top or bottom bolts in the torsion leaves had moved though. It was then, when I think I may have realised a second reason for it not moving....
I have a flipped ARB - as in the ARB is mounted to the top surface of the lower trailing arm:
As I jack the bus up the trailing arms lower and the ARB rotates up. What I hadnt noticed/realised was that when i jack the bus off the floor the ARB actually rests pretty much on the beam endplates and the chassis rails:
Therefore, am I right in thinking that if I am trying to raise the bus - i.e. rotate the trailing arms down - the arb is wanting to continue rotating up. But it cant because its fouling on the end plates/chassis rails?
This surely results in my only option to raise the bus would be to remove the ARB and fit to the bottom of the lower trailing arm in the Stock location?
FYI by bus is on its lowest setting on the adjusters (Albatross style)
NaFe
NaFe
