Removing Sliding door handle lock barrel Help!!
Jailed up
Sep 14, 2009
90
Is there an easy way to get the barrel out? Just broke one handle :evil:
Thanks in advance :)
All you have to do is undo the nut in the middle of the inner handle then the outer handle come out, then there is a tiny grub screw that releases the barrel
Mine was pretty badly corroded in.
Was hard work and destroyed the barrel in the process.
As above should be all on the grub screw.
Good luck.
Cheers!! Cant remember seeing a grub screw!! There was what looked like a pin going all the way through which I tried to knock through but ended up cracking the inner part of the handle! I'll have a look tomorrow!
Thanks again :)
