Max Power
I have a 1.6 t1 engine in a 1970 van,the engine code is AE which is twin port,the carb fitted is a 30pict 2 which runs ok but there is a slight damp residue from the throttle spindle and a slight flat spot midrange,I have stripped the carb but the bushes on this type are not replaceable,my question is are the gsf or similar remade solex carbs a direct replacement.I do not want to move away from a solex.The part 181vg0040 shown on gsf site says it needs a adaptor for a 34 pict manifold.Does that mean I have a twin port engine with a single port manifold,is that possible?can anyone recommend someone to refurbish and overhaul to fix the worn spindle?
thanks for any help
thanks for any help
