Bit more done today
Rear waist line bulge repair welded, ground back, etched, red oxide and high build
Will need a couple of high bits reground back but not too bad with no filler!
Rear window corner repair welded and part ground back
Need to finish this but Mac was grinding welds so headed outside to look at the sliding door away from the noise! There's too many pin prick rust holes and thin bits on the sliding door lower window
Anyway, I picked up one of these a few years back for repairs to the opposite sliding door panel, front rear and lower where it joins the sill.
But as it's a LHD panel the window opening and waistline profile are perfect for the sliding door on a RHD (I hoped!) so...
Seems a waste of a panel but it will all be used! and it fits
Instead of going for one long repair I decided to split it into three so I'll do the corners first leving the centre in place for reference, and then fill in the centre part at the end!
But that's all I had time for! so hopefully a bit more tomorrow!
