Don't you hate it when you pull your engine out and end up like this...
:msn4:
Here's the reason why though:
My tailgate is shot and has been leaking in a wee bit over a fair bit of time. Replacement sourced, just needs a little bit of a skim and paint.
About half a dozen pin holes that need attention... here's the largest. Not too bad, all things considered.
Found I have a very basic fuel sender access hole... should I do something to seal it up a bit better?
The black paint is pretty much where the surface rust stops. However the insulation that was down had retained a bit of water so had to strip that off to make sure what was underneath really was good.
To do this I had to pull the Westy bed out (and can now finally get the side panels recovered) as it was fastened underneath.
One step forward and all that :roll:
Also pulled the firewall off to check everything underneath. Pleasantly surprised, so just a repaint of the firewall (it was red and is now a darkish grey... ran out of the lighter shade) and re-install.
Then strip and paint above the gearbox and along the chassis legs a bit followed by installing the leccy fuel pump, pipework and am in the middle of re-jigging the wiring.
Sorry for the potato quality photo but it was late and dark by the time I gave up this evening.
Busy, busy, busy... :mrgreen:
