Hello folks, I'm in the process of re-wiring the camper, and wondered if anyone with a bit more electrical knowledge than me could offer some advice! When running the alternator output wire (6.0mm2 red), the wiring diagram suggests to feed direct to the battery. Is there any reason why it couldn't be run directly to pin 30 on the starter as this is obviously still feeding the battery, it's just a slightly longer cable run?
The reason I ask is because in the past I've had a problem whereby I needed the engine running with the battery disconnected and also had the battery positive terminal work loose. In both of these instances, the engine cuts out as soon as the positive terminal is removed. If the alt feed went to the starter, the alt would at least keep the engine running if there was a problem.
I'm not sure if there is some safety reason for this, but I can't think of anything myself.
Sent from my iPad using Tapatalk
