Marvel said:
Nigel, that is some display panel you have there :shock:
You sure you need all those gauges? NIgel should now be known as a gauge-whore!! :lol:
That's just the start! :lol:
The gauges & warning lights, I have available at present, are:
80 mm VDO Cockpit, dual-scale (i.e. mph & km/h), accessory speedometer, with trip odometer
80 mm VDO Cockpit, 400~7000 rpm, ignition-sensed tachometer
60 mm Lucas, 8-segment, warning-light clusters (2 off)
52 mm VDO Cockpit, 0~5 Bar oil-pressure gauge
52 mm VDO Cockpit, 50~150 ºC oil-temperature gauge
52 mm VDO Cockpit, 40~120 ºC water-temperature gauge
52 mm VDO Cockpit, 50~300 ºC cylinder-head-temperature gauge
52 mm VDO Cockpit, -25~0~45 ºC ambient-air-temperature gauge, with integral frost-warning light
52 mm VDO Cockpit, 8~16 V voltmeter (ex 1984 VW Golf)
52 mm VDO Cockpit, quartz time clock (ex VW Scirocco)
52 mm VDO Cockpit, fuel-level gauge / indicator (dip-pipe type)
52 mm VDO Cockpit "Night-Design", 0~6000 rpm, alternator-sensed tachometer
52 mm Time Instruments, 0~30 in.Hg inlet-manifold vacuum gauge
52 mm Lucas, -30~0~30 A internal-shunt ammeter
52 mm Lucas-CAV, -60~0~60 A internal-shunt ammeter
80 mm VDO Cockpit, 400~7000 rpm tachometer, similar if not identical, to the one I have
52 mm VDO Cockpit, 50~150 ºC oil temperature & 0~5 Bar oil-pressure gauges
52mm VDO Cockpit, -25~0~40 ºC ambient-air-temperature & 50~300 ºC cylinder-head temperature gauges
52 mm VDO Cockpit, quartz clock & fuel-level indicator
52 mm VDO Cockpit, 0~16 V [SOLD] & 8~16 V voltmeters
52 mm VDO Cockpit, -1•0~0~1•5 Bar turbo-boost [SOLD] & 40~120 ºC water-temperature gauges
52 mm Time Instruments, inlet-manifold vacuum gauge & 52 mm VDO Cockpit "Night Design" 0~6000 rpm alternator-sensing tachometer
The VDO Cocpit gauges I seek, as either first-time acquisitions, or as replacements for non-VDO Cockpit instruments, are:
52 mm VDO Cockpit, 0~6000 rpm, alternator-sensed or ignition-sensed tachometer
52 mm VDO International Cockpit, 0~900 ºC exhaust-gas-temperature gauge
52 mm VDO Cockpit, -60~0~60 A external-remote-shunt ammeter
52 mm VDO Cockpit, 0~30 in.Hg inlet-manifold vacuum gauge
http://www.egauges.com/vdo_mult.asp?Type=Vacuum&Series=Cockpit&Units=E" onclick="window.open(this.href);return false;
52 mm VDO Cockpit, -60~0~60 A internal-shunt ammeter
There don't seem to be any low-current range (i.e. -30~0~30 A, -50~0~50 A or -60~0~60 A) ammeters, with external remote shunts, in the 52 mm VDO Cockpit, Profi Cockpit, Black Cockpit or International Cockpit series. Hence, I have in mind to obtain a VDO Cockpit internal-shunt ammeter, from which it should hopefully be possible, to remove the internal shunt-resistor and convert it to remote-external-shunt operation.
