Ok so I've put the original spring plates back on the bus. The idea was to turn them up an inner spline so try and get a slightly higher stance the back.
When the plates were in their unloaded position ie off the stops they looked to be roughly the same height. But now it's off the stands it's higher on the right :evil:
Obviously you only get one chance at this. So now I've got to take it all apart and have another go. Really don't feel like doing this again in a hurry though!
The only consolation is that the threads in the hub carrier are stripped so I'll probably replace this at the same time unless anyone can tell me it can be mended?? At the moment I've just replaced the M14 threaded bolt for a M12 nut and bolt all the way through
Can anyone tell me what the standard measurements should be. And if anyone out there knows roughly what combination of inner and outer spline adjustment is needed to get the bus sitting right.
Hmmmm - not bloody right :evil: difficult to see but the right side is obviously higher - mrs thinks its well funny that ive been out there for about 5 hours in total!!!
195 R14 tyres on the back
left side not too bad?
right side def too high
Front with 185 R14 tyres and KYB GR2 shocks which i think are a bit too hard really....
left
right
left
right
