creationblue
nora said:Autocraft do the brake fluid reservoir http://www.autocrafteng.co.uk/shop/...rake-fluid-refill-reservoir-typ-2-68-72_2234/
Thanks for the link 8)
Steels FTWcreationblue said:A few jobs being done over the winter so time for a small update.
The 090 transmission has had a leak from the drive shafts for some time and seeing as my engine no longer (for now at least) leaks then it was time to get this job sorted, it took a few weeks to get the seals, but now that's ticked off the list, also it was found the front gearbox mount had worked itself loose..
I had some serious popping on overrun coming out of the chevy, I pinpointed it to a blown diaphragm in the vacuum can on the side of the distributor, whilst I got a replacement easily enough it didn't cure the problem. Luckily it was found that a leaky jet on the ICTs was the culprit and an easy fix 8)
Next up was the rear drums, my handbrake once adjusted would never hold for more than a few days, once off and on closer inspection it was found that although the pads had seen better days someone had turned down the inner face meaning the adjusters were at full lock
replacements will out last me![]()
I thought it better for the handbrake cable to sit underneath the arm rather than through the hole as it gives it a better angle.
Next up to change the front brake flexi's as I'm getting a slight drag at times on the nearside disc and I thing the rubber hose might have collapsed on the inside.
And finally for 2017 steel wheels are making a comeback 8) :msn4:
This pic is from a few years ago, but I'm hankering after my steels :fyou:
67westy said:Steels look great, the best wheels by far. Is that better?
Sent from my Nexus 6P using Tapatalk
creationblue said:It arrive today in the pouring rain, infact it probably saw more rain today than the last decade in CA :lol:
Note the new roof canvass
I couldnt get the palm trees in on these shots!
CB 8)
