creationblue
Got up nice and early (kids :? ) time to get the bling on 8)
Started off by taping a line around roughly where the trim will go, then taped it into place making sure sure everything lined up
Once i was happy everything lined up i then drew a line under the trim all the was round, then marked out the fixing centres.
Next i measured up 12mm from the line i drew being the bottom of the trim to get the centres, checked i was happy again with the fit then drilled a pilot starting with the cab door and worked to the corner using a spray of waxoly with each hole i cut
I did a piece at a time but left the corners and the hatch trim till last. The corners were suprisingly easy fitting a treat without any fuss, i then made sure the rear hatch section was level and lined up with the corners then voila 8)
The trim isnt perfectly straight with a few dings and bends, but suits perfectly the look of the bus, in my oppinion anyway :lol:
I have to say i really enjoyed this job and im well pleased with the look then went out for a drive with the kids & mrs whilst the sun was shining 8)
Just
Just
