needed a trailer board for when i take the bikes out, so made one out an old skateboard, some lights i brought for a trike i was gonna build and a cali number plate from a boot lid i had imported
you know the drill by now i get board very easily, so it was time to change the colour of my wheels again ...... baby blue or bubble gum pink ...... can you guess what it is yet ?
aircooled profiles
seen this before ?
taste the rainbow. cream, orange, brown, white ....
first thing one of sisters said when she came round was "god Ash you really are gay" then a mate popped round and he said "why the fuck have you painted your wheels pink ?" and finally i got "so when did beige and pink go together ?"
not 100% myself but look kinda cool, gonna order some new crome domes in the morning think that will sort it out
could not get it to run so took it to simon at absolute vw and he said altho new the carb was no good, so its gotta come off, but thats not the best bit on the was back my dyimo (second hand fitted 2 days ago) packed in. So its engine out time again. to cheer myself up limped it over a feild for a bit of impulse camping
i got to be far to you mate after reading your thread i dont think ive ever seen someone with a rocket up its arse as you i take my hat of to you fella
i do remember being quite the same :lol: :lol:
after having the bus running for a full week it was time to drop the engine again, to fit the new / upgrade to a 75 amp altenator and while its out i'll fit the second new carb, should be receiving the altenator monday / tuesday and gsf will have the carb tomorrow: might tart the engine up while its out, nothing mechanical just colours i might get the rattle cans out i have about 5 half full cans in very different colours :msn4:
second time of taking an engine out a bus, lessons have been learned ! jacked up nice and high to work under it, chocked gearbox and a jubily clip on the fuel pipe underneather for quick release
swapped to an 75 amp alternator, decided to throw some colours into the engine mix while it was out. In volksworld is says an alternator change should take 4 hours labour :lol: my engine was out for nearly 2 weeks i did everything wrong i sprayed the carb stand / inlet manifold pink and orange, then when i came to fitting the brand carb it was more then fouling :x spoke to ssp (who i brought the kit from) they said just grind your alternator where it fouling :shock: so i did nearly went right through it but it was still fouling, so with my old carb i stripped it and turned the fuel pump setting key the other way round, ground a bit off the screw and finally got it to fit. Then when i fitted the alternator i used the backing plate from my genorater as it was crome, fan spun fine until the fan belt was tightened the it would catch really bad :x shimed it both ways bolted all back together and it was still not right. The crome alternator pully that came with the kit was more bent then alan carr so while i was picking up a new one from GSF i told him about all my hassle and he said you must have an beetle inlet manifold and i also needed to use the backing plate that came with the kit .... he was right, with inlet manifold and backing plate swapped it was on !
this is how it did look
this is how it stand now
even got it in for a late night jet wash the fan catch's the fan shroud at about 5000 rpm and makes the worse noise ever to after rtth it will have to come out again, never really worked on these before but you soon learn :lol:
adolf kitler is a very strange cat, went to work on my bus and he was asleep on my battery tray with the boot lid closed
