cyberdyne systems
- Joined
- Aug 21, 2008
- Messages
- 634
- Reaction score
- 0
Ok so I run the standard carb and distributor and air cleaner, I've got the same set up in my bug. I can set up the bug carb ok and it runs well. I set up the bus one (rebuilt solex with no shaft play), but on the initial settings of 2.5 turn out on the mixture screw I get a pulsing where it slows and revs. Once i have opened the mixture up quite a bit more I find a much smoother running and can lower the revs back down with the bypass screw. Is this fine or do i have a problem as i can't set it near the initial settings? I checked the plugs and they are a great colour with no soot. Oh one last thing I just rebuilt the distributor as a spring came off the advance weights as the retaining bit was broken, fitted new points and the dwell measures just right.
The reason i'm asking is I have had a hesitation when accelerating or under load up a hill say. Like a misfire. I have cleaned out the tank and fitted a new screen filter in there, I have a paper type filter in line under the tank, plus the late model fuel pump has a screen too. Now this was before I rebuilt the distributor which may have caused/contributed to the hesitation. But still I can't set up the carb at the 2.5 turns.
Two things that may effect it are the carb to manifold joint doesn't seem flat (without the gasket in place) so its the gasket thats making a seal (but if I was gettting a leak here, how come spraying it makes no difference and I can set it up albeit with more mixture). Also there are no cooling flaps or themostat, so this could mean taking longer to warm up the manifold once the choke is off, and there definately is an improvement when its been run for longer (I don't see icing but the manifold is cool to touch). I cleaned out the heatrisers too - though with an aftermarked 4 - 1 header (drilled heatrisers) only one side gets hot as the design doesn't pull through like a stock exhaust, and the air cleaner has the warm air feed working).
Just wondered what opinions are on this?
