Type 4 engine in an early bay
macca's bay
Active member
Jan 8, 2012
37
Hi All
Has anybody fitted a type 4 motor in to an early bay :?:
I've been given a porsche 914 engine and wondered how easy/hard it would be to fit into my bay :?:
Cheers Paul :roll:
Yes, can be done but a bit of work required:
http://www.thesamba.com/vw/forum/viewtopic.php?t=375224
Jake Raby does some tinware templates to seal the engine bay (along with the DTM shroud):
http://www.aircooledtechnology.com/cooling/pricing/stage3.shtml
The early bay does not have too much in the way of gearbox support, you may need to add something:
http://www.aircooledtechnology.com/cooling/fit/bus-mid.shtml
You'll need a modified engine support bar too:
I'm sure folk who know more will be along to fill in some more detail...
Hi
Thanks I've seen some info on the type 4 store about the support bars and dtm fans but it all looks abit expensive.
I wondered if anyone does anything like it in the uk? :roll:
http://www.kustomcoachwerks.com/forums/viewtopic.php?t=6639&postdays=0&postorder=asc&start=0" onclick="window.open(this.href);return false;
This is super cool an good work
Rob
macca's bay said:
Hi All
Cheers Paul :roll:
Is it a 1·7, 1·8 or 2·0 litre, VW-Porsche 914, VW Type 4 style engine and does it come complete with its Bosch fuel-injection system?
Rob
That is a six-cylinder Porsche engine, rather than the VW 17/18/2000 Type 4 style engine, used in the VW-Porsche 914. There were a few VW-Porsche 914-6s, which used the six-cylinder Porsche engine, but they are something of a rarity, especially in the UK.
macca's bay said:
Hi
Its a 4 cylinder 1700,type 4 engine on twin carbs..
Shame its not a 6 cylinder.
I suspect that those carburettors are a retro-fit, as I would expect the VW-Porsche 914's, VW 1700 Type 4 style, 1·7 litre engine (1679 cm³ displacement, 66 mm stroke x 90 mm bore, with 8·2 : 1 compression ratio => 82 DIN hp @ 4900 rpm & circa 132 N.m @ 2800 rpm; to the best of my recall, off the cuff), to be the same as the VW 411LE, with Bosch D-Jetronic fuel injection; except for the Porche-specific flywheel, coverplates and exhaust system.
naskeet said:
macca's bay said:
Hi
Sounds more like a standard bus engine if its on carbs
Sent from my GT-I9100 using Tapatalk
mattyd72 said:
naskeet said:
macca's bay said:
Hi
If it is a standard 1·7 litre bus engine, then it will have both reduced power & torque compared to the VW411LE engine; peaking relatively high up the rev range (7·3 : 1 compression ratio, 66 DIN hp @ 4800 rpm & peak torque - forget how much, but << 132 N.m! @ 3400 rpm), so not the best choice, for a VW Type 2.
