URGENT HELP REQUIRED!! van won't start
Ronin
Jul 12, 2010
49
Where the Cider drinkers come from
Not used the van for a few weeks as I've been working on it but come to start it and there's nothing from it, battery is fine
Work I've done since it last ran is:
Changed fuel line (had a leak on last one)
Fitted heater control levers/connected cables
Lubbed speedo cable
Fitted curtains
I've checked the battery and that's fine
When I turn the key I get nothing, even the generator and oil light don't come on in the dash pod or the fuel gauge but hazard lights work
Looking for ideas where to look, I've got the clock pod unscrewed again but can't see any loose wiring
Thanks in advance
mattd1984 said:
Sounds like battery mate, try charging it up maybe? or using a jump leads
No definitely not the battery, I tested that and got 12.8volts also put it on charge just incase and the charger dropped right down as it didn't need much.
I have got it running now, possibly a faulty ignition switch as I had the ignition cowling apart and was testing the wiring with a multi meter and touched 2 wires at same time with the probe and it came back to life.
Was a bitch to get going though, ended up taking the new fuel filter out as there was virtually no fuel flowing through it.
