gagvanman said:
Abel, thanks for your input.
How heavy is your Bus?
Not sure, its a standard Dormobile early bay with lightweight furniture and 3/4 rock n roll bed (no spare wheel).
What is your cruising speed on motorway?
60 - 65
At what revs do you normally change gears?
Between 2k / 3k depending on engine load.
How high do you like to rev?
Never go above 4k
What percentage of city and motorway driving do you do?
50/50
Hey Gav
Ok, so based on your info, here`s my suggestion and why:
Cam- Stock. Yes, stock cam. Why? Because you never rev past 4k rpm, and the stock cam maxes power up to around that ish. Plus, there`s no other cam that will give you as much torque down low as the stock cam. Also is free, and you can use all stock valvetrain, which will make the engine more reliable, needing less maintenance and quieter.
Heads- Sell your CB`s (Your CB heads are too big for your needs and using them will hurt low end torque, and you won`t be able to use it to it`s full capabilities due to the rev range you use the engine) and get a pair of AA 500`s stock size valves. With a little clean up of the ports, they will flow much more than your requirements, plus they use long reach spark plugs which makes the head stronger around the plug area avoiding cracking. Also they have a modern heart shape chamber, very efficient. Chambers are 54cc`s, which will give you a compression of aroun 7.8:1 with a stock deck height of 1.25mm. Perfect for max efficiency.
Carbs- 34`s are great, i use them a lot, very reliable if usung a CSP Bellcrank linkage, setup and forget. Use a stock fuel pump, then hook up a gauge on the fuel line, then grind the pump rod until you get 2.5 psi fuel pressure. It will work as a charm! I use always 145 mains, 160 airs, F78 emulsion(works for me perfect), 55 idles. More than 20 combos with the same jetting, so more than proved.
Crank and rods- Stock are perfect, if you can, balance the rotating assembly for smoothness and more longevity.
Exhaust- If you can, use a 1 3/8" 4x1 header with a silencer of your choice. That will give you a few extra ponies.
This combo gives a solid 75bhp at the crank, but 100-105 ft/lbs of torque as low as 2k rpm, the engine feels really responsive, specially at low revs. Perfect for your application
Abel
