Which accelerator cable?
AxlFoley
Jul 19, 2008
2,741
cardiff
I have a LHD bay with an 1600cc SP and an alternator and single carb, the carb has a spacer that's about 1" tall to allow it to clear the alternator, the issue is that when I bought an accelerator cable it was too short, I was just wondering if anyone else has had this issue and if so what cable did you buy?
Thanks in advance
Mark
Yeah I had the same issue, bought the correct teatime from vwh and it was waaaaay too short ( '72 X-over with 1500sp) so had to order a universal one from Gsf and cut to fit :evil:
any modifications will lead to the stock cables not fitting.
I always recommend anyone with a modified carb situation be it twin carb or raised single carb go to the following cable:
https://www.vwheritage.com/shop/AC7214863/universal-throttle-cable-kit-fit-all-aircooled-models-15ft/" onclick="window.open(this.href);return false;
Its a big benefit over a stock carb as its a heavier duty stranded cable so will last longer anyway.
Hope that helps.
I had s similar setup and the same problem.
1600 SP, single carb, spacer, alternator, broken accelerator cable.
I bought the 1970 RHD accelerator cable, which was a bit short.
So I tried without the carb spacer.
It's a Brosol H30 and the accelerator pump mechanism on the right side *just* clears the alternator body.
I was prepared to grind the alternator a bit, but no need.
Might be worth a try if you didn't buy the "right" cable yet?
Thanks for the link Alex, I bought one of those. Well two actually, one spare ;) nice job for the weekend.
