did you fit both seals? there's an o ring one to inside the part that bolts to the crank - gets overlooked
you need a dial gauge really - you can do it with digital calipers, which you also need so you could try with those first.
The idea is there is an inbuilt allowance for the crank to move longitudinally[sp?] , called end float...3 shims are inserted to get this measurement to within the optimal range 0.07 - 0.13mm, as the engine wears the measurement increases and you can reshim the pack to get extra life until the day a thrust cut is needed.......
*rest of lenghty post removed as Noddy's explanation is much better :mrgreen: *
