123 Distributor
stevefhot
Oct 16, 2007
50
Colchester
Hi, has anybody fitted one of these as i am about to. Is there a prefered setting as there are 14 to chose from, its a 1600 t/p with 36 drla Dellortos.
what is your engine number?
Start with curve 0 then adjust the timing if you need to.
heres the pdf list go to the application sheet that will show the correct curve for the timing you initially set. Ive seen two 1600 TP beetles with these and they were both running on the curve 0 with no problems.
http://www.123ignition.nl/downloads/manuals/123VW.pdf" onclick="window.open(this.href);return false;
I have one fitted but only towards the end of last year, so whilst all seems good, I haven't done much mileage with it. My mechanic left it as factory setting, 0. His opinion was that the different curves didn't mean much due to the set up I have and it being a camper. I do trust him but I may well have a play when the weather gets better and i can compare any differences. I have a 1600 tp with 34 ICTS.
I have a 1600 twin port engine, single 34 PICT-3 carb with a 123 dizzy, set to curve 0. It runs really well and starts first time every time.
Went for a 60 mile run with the distributor set on 0 curve, felt really smooth no flat spots and seemed to pull a bit better up hills :) . Has anyone tried the multi-spark-feature of number 2 curve.
Hey guys,
I'm veryy interested in one of these dizzys, where did you get yours from as the price seems quite variable depending on the exchange rate......I saw that there was a carb place down south selling them butjust wondering if there were any bargains to be had :mrgreen:
Olly
Hi Olly, i got mine from theses guys, very quick service. http://www.sciperformance.co.uk/onlineshopproducts_53353/prod_49226-123VWR.html" onclick="window.open(this.href);return false;
