G
Guest
Guest
faux said:AxlFoley said:Based on that responce all lowered busses should run shorter axles due to the change in distance from the inner and outer CV joint![]()
I had one of these kits and it had everything there to make the job easy. The shafts were a little longer, it had a gear shaft extension and longer clutch cable........but I know that Deano made his own bracket and used og shafts and been running like it for years.
With your skills Mark you will sort it easily.
i was led to believe it was a bolt up and forget piece of kit. So sounds like it should be easy for a noob like me.
