Hello thomas.
Thank you
I used a paint remover in gel...Like this one, I guess:
and a pair of tools like this one:
here's a Hugo's friend removing the old paint from a '63 bug using this method:
but you can also use a heat gun to remove your old paint.
http://www.frost.co.uk/result_search.asp" onclick="window.open(this.href);return false;
or,
Some say it's better because of very small traces of paint remover that can be left under the new paint.... and they can begin to oxidize the metal sheet underneath it.
If you decide to use a chemical paint remover in gel, you will need to clean the body extremely well before paint it again.
You will need also a breathing mask, a pair of proper gloves (gloves able to resist to the paint remover), some old clothes and a pair of protection glasses
you can also use these kind of abrasive nylon discs:
but be aware not use them a lot in the same area... they can heat up and wear the metal sheet.
Here's another of Hugo's friend using one in the same '63 bug:
I sure hope this helps you
