Looking forward to taking it for a rip with the updated engine spec now is a follows:
2110cc built and blue printed by Hector Howe
AS41 case, shuffle pinned, full flowed and welded behind no3
CB performance 4340 chromoly 82mm super race crank with chevy journals with silverline steel backed bearings
Genuine VW vanadium flywheel, 8 dowelled and full weight and Gene berg 36mm gland nut
Gene Berg equaliser pulley with Berg twin washer bolt
kennedy stage 2 with dalikin super disc clutch plate
CB performance 5.5 H beam super race rods with clevite bearings
CB performance 8mm chromoly head studs
Mahle forged 90.5 'b' pistons & barrels, pistons lighted and match weighted
Total seal gapless rings
Engle FK10, .385" Cam Lift, .539" Valve Lift (1.4 Rockers) 310 degrees of duration & 108 Lobe Center with silverline steel backed dual thrust bearings
Scat pro-comp 1.4 bolt up rockers, which actually measure 1.45
Scat super light weight lifters with Gene Berg oiling mod
Manton cut to length chromoly push rods
Fast fab spring loaded push rod tubes
CB performance 044 ultra mag heads, dual springs, stainless steel 42x37.5 valves with scat lash caps & hand ported
10:1 compression, no head gaskets. Cylinders lapped to heads
CB performance 'big beef' match ported manifolds
Weber 48 IDF carbs with velocity stacks/no filters
Holley fuel pump and pressure regulator
CSP bell crank linkage
Gene Berg 30mm full pump with Berg pressure relief pump cover
CB performance 2 litre slim line deep sump with welded pick up tube extension
Remote Fram HP1 oil filter, mocal sandwich plate and 72 row external oil cooler with scoop
Scat tinware powder coated along with type 3 under cylinder tins
75 amp alternator with CB performance billet pulley and Berg welded fan
Al's headers merged 1 5/8 header with Dynomax muffler
Vented stock rocker covers
Fast fab fuel pump block off with breather
Fast fab breather box
Rotating assembly, pulley bolt to clutch dynamically balanced to '0'
Genuine Bosch 009 with Petronix, MSD blaster 2 coil, MSD soft touch rev limiter, Taylor 8mm leads and NGK plugs
Estimated 180hp +
