VWAIRCOOLED
Good work dude.
How are you going to join the A pillars? On mine I cut a larger section of the A pillar front panel skin off the donor and rotten sections first.Then worked out the best place to join using the best metal possible.Then you will notice that the main A pillar itself under the skin is two halves of box section.So rather than cut straight through and but weld it up,cut each half at different lengths so you stagger the join in the box section(for extra strengh in the joint).With careful measuring and cutting you can get it right first time without having to trim it later.Using a hacksaw rather than a grinding disc will give you more acurate and neater cuts here.I maybe could have put more distance on the staggers,but I'm happy with how it turned out.Good luck with it! Oh also you'll find some wires going up the pillars for the interior lights and stuff.On mine I accidently cut them because I didn't know they where there at first,I remade them later,so it's probably better if you can take them out first.
Snap with the front panel
