Well, the plan was to get the bus ready for Vanfest, but she is not ready for Mot yet.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Work has got in the way of the resto so not done anything for a week.
That said, she aint far off. I have sorted the lights by fitting the rear cluster from my '71 swiss bus and runing a new wire from the wire off the hazard switch. I also fitted a pair of the Machine7 clear head lights that were on offer and rewired the side lights. Very useful sticky on the Tech forum.
Got the passenger side cab floor repaired and the battery tray in.
Had more re-construction work to do on the cab step and lower arch front before I could tack the badly fitting repair panel in.
Drilled out the spot welds on the top part of the rear closing panel.
The tray came out really easily
Got to tackle this area next and then a few patches in the cargo floor, oh and the bulkhead of course.
It was nice and dry on the inside.
Little bit of rust up top, which is ground off and treated now. Will be fabricating a new piece tomorrow from the replacement bulkhead as there is spare metal there.
Cleaned the surface rust off the discs (rotors, as the US boys call them!) and took her for a spin up the road. She bottoms out on the arches at the slightest bump, so I have no choice but to raise her up as I have no funds for a couple of lower profile tyres at the mo
I also fitted the four CV boots and cleaned the joints. I think I will be needing some new CV's soon too, as there was a bit of wear on the bearings. Drive shafts are rubbing on the chassis at the rear as there is only about 1" of clearance between shaft and chassis. That gonna be a problem when I got a full payload of 5 sprogs and the Missus. Short term I will raise her at the back a couple of slpines.
Plenty to do before Mot then!
