Just an update of whats been going on.
Both sides of the floor are now in which became a complete headache due to the complete cab floor not fitting and me having to chop it up.
The beam is also in greased and undersealed so it should last until I start to tickle it with a lowering stick.
I stripped the interior out to reveal what nasties i assumed were there but fortunatly all was relatively sound, so a lick of paint was all that was needed to tidy it up!!!
Also welded in a new chassis rail on o/s aswell as new 6mm strength plates on bothe sides.
The front end has also had four new ball joints, four new bump stops, new dampers, and steering rubber coupling.
[/img]
I have undersealed all the way from the front upto the rear torsion arms which i spruced the underside up a treat
All that is left to do now is sort out a feed to the bulb on the dash for the main beam warning light, get the horn working again and a new n/s headlight and its off to the garage for a new ticket :wink:
I hope :!:
