Might be able to deliver if that helps @ 40p/mile return trip?
Genuine 103 mm mahle barrels and pistons
• Match ported manifolds
• Extensively reworked heads
• 3 Angle Valve job
• Clearanced case, lightened and balanced
• Heads have a 58cc chamber
• Compression ratio set at 8.9-1
• Schleicher 324° Cam with special grind
• Powerband from 3,500 to 7,500 rpm
• Twin weber 44 carbs/linkage
• BAS thermo oil block/external oil temp bypass
• Genuine Porsche cooling; 11 blade fan with built in regulator
• Balanced rods/crank/lightened flywheel
• All lightened /balanced/blueprinted and match weighted
• 8mm stainless valves
• Re-worked 2 litre Porsche crank, nitride, balanced
• New barrel shims
• New pushrod tubes
• New chromoly retainers
• New dual valve springs
• New DIS-IX Ignition System for 009 distributor
BWA time;
http://www.buseswithattitude.co.uk/cms/index.php?page=retro
quote; This is more a driving, rather than a racing engine (although if the compression was increased, I was told 14’s would be reached without trying too hard), it’s a silky smooth motor with torque and instant power from all rev ranges or speeds… opposed to a type 1 motor which relies on rpm and/or dropping gears etc to make power or get moving.
Type 4’s are so superior it is painfull to think of building or buying a big bucks type 1 engine which run stressed, hot, and make less power than a decent type 4 anyway!
Brand new
DIS-IX Distributorless Ignition System For the 009 Distributor fitted.
Triple the energy of Conventional Electronic Ignition Systems! It includes all electronics, custom ultra high energy coil pack, silicone spark plug wires, and all wiring, connectors and mounting hardware.
• Max HP
• 60,000+ volts output
• Instant starting in any weather
• Maintenance free
Did I mention it comes complete with a special
stainless BAS 4 into 1 merged header?, it has separate risers to prevent the head studs pulling under warm up (like a Porsche) it’s has a totally merged system with springed collector, all stainless etc. sounds great
naff video –
great engine!
[youtube]PGAlUErtrzA[/youtube]
