abby said:
This is a great help guys! Thank you.
I am definitley doing it myself, so there will be no putting off! Haha. I'm swaying towards 2pack as although trickier, it gives a longer lasting finish from the sounds of things.
MisterListerSir - Your van looks bloody brilliant! How long did the sanding/painting take? I agree the satisfaction afterwards is worth doing it alone. Plus, our van is a piggin' mess at the moment, so it really can't look any worse :lol:
Cheers Mate, not sure how long it took was between work and I had to mask up a few times as I painted the inside first( same colour as the roof and bumpers), then a u-pol 2 pack filler/primer before the main coat. To be honest I found 2 pack easy to use once I got my third gun a quality DeVilbiss one as the 2 pack thinners ate the cheap ones. But I did spray it all with one of those small cheap wolf compressors!!! you'll need good spraying overalls thick gloves (again the thinners eat thru the thin mechanic gloves) measuring cups, and paper filters. Buy plenty of 2 pack thinners as you need to clean the gun properly every time. The main problem I had was flies in the barn I swear they sit around waiting for your last coat. Another benefit of spraying it yourself is you can lay on as many coats on as you like....I swear if mine had one more coat, the doors wouldn't fit back in
