Matt_B
Just put my engine back in and it's running sweet with 2 new heads
However, a problem I had before seems worse now:
There is an annoying whining noise when the clutch is pressed in, even just a little bit in and it starts the noise.
I replace the clutch bearing thinking it was that, taking the opportunity whilst the engine was out.
Other than the noise the gear change is fine and smooth and no slipping, inspection of the clutch was fine, what else could it be?
