dubdubz
Anyone a real dell expert/guru?
I need your help - I'm stumped
from a thread I have running over on vzi....
I have an issue and wondered what you would consider is causing it....
recap - Dell 36's on 1745.
Trying to set best idle, one of the adjuster screws doesn't do anything.
I have put 52 idles in and have set all the others but no.2 cyl won't stumble when screwing the adjuster screw in. It seems the adjuster does nothing???
I do remember I had this before and cleaned the carb ...took all the jets out and blew out with compressed air.
In fact I can screw it all the way in and the idle doesn't change.
I have the mains removed....[having them in doesn't change it as I'm only trying to set the idle]
not sure what to do with it, any suggestions.....wondered if I should move the mixture screw to another cylinder and see if the fault moves indicating a dodgy mixture screw?
many thanks
Darren
then after suggestion of cleaning stuff out I posted
I have had both carbs stripped down and blown everything out - or so I thought. The jets are new put in today, this cct was problematic before which makes me wonder about something else?
I'll try blowing it out anyway as a normal precaution, then I'll pull the mixture screws on that carb and compare
so I put the carb back on today, and it is pretty much the same so I'm stumped
the screw still doesn't do much , it seems to have to be turned out further than the others and it doesn't seem as responsive.
for eg
800 revs, turn the no.4 mixture in 1/4 turn wait, 1/4 turn etc then the revs drop as expected slight stumble, turn back out..revs pickup. Also if the plug lead is pulled the engine noise obviously changes.
Now on 2 it seems that you have to turn out a couple or 3 more turns, and then the pickup/stumble is slight, also I have pulled the lead on 2 and the noise doesn't change as much or at all, until the idle mix is what I would consider much further than the rest?
So I think that I may still have a blocked passageway still on that idle, the only thing I haven't yet checked is the compression [ the top end is all new ]
I don't want to poke anything in there but what is the best way to flush the bottom hole out?
any suggestions? how or what is best to blow/poke out the idle passageway as I'm thinking this is blocked still?
I am also going to do a compression check just in case the deck height spacer could be allowing blowby?
many thanks
Darren
for eg
