Hi
In the process of fitting CSP adjusters on to a early bay beam .Wanting to drop the front of my Westy 40 to 50 mm.Has anyone fitted the top adjuster to the front of the beam instead of the more usual l spot at the rear. The adjuster will then not hit the gearshift tube.It means I will have to redrill the trailing arm dimples on the top leave stacks , Thoughts anyone ( some photos also of a piece of pipe that I used on this scrap beam to push the centre leaf retainer sideways to cut the slots without drillling the dimples and a puller /drift to remove/ install beam bearings)
