james_stan
Hi folks
Beam was stuck in full but I pulled the switch (indicator/flash) stalk to check wiring and it switched to low..?? Now it's stuck low and I'm uncertain why. I replaced the relay several years ago and relocated it to slightly away from the fusebox and windscreen leaks.
Looking at the wiring is looks like the dip beam switch connects the S terminal to GND ( the switch itself is good - checked with DMM) so I guess I can double check teh relay by connecting a wire to that S termail and touching it to chassis/GND...yes?
..also while inspecting the igntion/ flash switch arrangemsnt I spotted a loose GND/Earth (same group as red, red/black and black) that I don't have a home for. Seems to be
part of teh ignition switch, anyone know where this should connect to? (see pic)
