Horn wire/ brake fluid resevoir
charlie34
Sep 5, 2015
119
Hi guys
So piecing together a van I didn't take apart has is proving awkward. I've got the yellow wire that runs down the steering tube from the horn ring. Am I correct in thinking this terminates to earth?
The other question is where does the brake fluid reservoir sit, the little round one for filling up?
Dan
Sent from my iPad using Tapatalk
Horn:
The wire from the horn push terminates on the steering box side of the steering coupling.
Then the wire from the horn its self clips to the floor on the underside of the van, passes up through the hole in the floor with the column then through an eyelet on the inside of the cover that bolts to the floor, the wire then connects to a male spade tab thats on the outer column.
Brake res:
Depends on year of the bus but a 70 mounts behind the drivers kick panel, it slides onto a mount. Your best bet is to buy yourself a copy of the Bentley workshop manual.
Nice one cheers, I had a feeling it was on the steering box, but wanted to make sure.
Sorry forgot to add its 69 lhd. I'll take a gander there then. I have a Haynes manual, but I couldn't quite see it clearly enough. Are the Bentley ones a better option?
Yes I find the Bentley one to be quite good.
