Made some more progress today, nearly got all the welding done now.
The arches were blowing through when I was welding them so cleaned them off and cut them out
Made some plates
Cut out the last bit of grotty cab floor that the repair panels didn't reach
Flat plate would have been easy, but I wanted to keep the pressings in the floor so used the bits I cut off the floor repair panels
Welded them together
Repaired the arches
Welded the floor repair section in
Ended up plugging the last two holes with some small patches
With the cab floor all finished I started on the fuel tank bulkhead.
The centre section was rotten at the bottom and needed repairing.
Made a plate to fit
Welded up and then did some careful grinding
Trial fitted it with the removable panels. Need to made up the piece that are welded to the floor now
And a more effective alarm system decided to install himself!
Doesn't look as much of a pup as he did in the first photo on this thread.
