My guess is that your heat riser tubes on your intake manifold are clogged with carbon. This tends to happen through years of use. Heat from the muffler travels up the tubes to help warm your carb and help prevent an icing situation where the intake and the carb meets.
Your options? Find a new intake manifold that isn't clogged (you will be able to blow clearly through the little feet) or clear it with an oxy torch, hitting the riser tube with a hammer to knock out the old carbon...blow out with high compressed air afterwards.. The 2nd option is what I tenderly refer to as "the bloody knuckler". Find an old clutch cable and cut it about 1 foot from the hex (rear) end. Put in into a drill and insert it in the heater tube, using the REVERSE mode so the cable won't unwind.
The heat method seems to work better, is less dangerous and is more fun.
