THE LAST PANZER
Over the last few weeks i have been rebuilding my engine after i found out my case studs were loose. Before i stripped it he was running fine.
I stripped it to the block cleaned it and replaced the case stud with lock tight making sure everything was clean and tight, de-coked the pistons and heads, set the piston rings up and refitted them with new gaskets and rubbers where needed.
i Re jetted my carbs to 55 idle jets, 150 main jets, 170 air corrector and F6 emulsion tubes. These were cleaned and re built very carefully and then fitted to the engine along with the cleaned fuel pump and new SVDA Distributor with new points and the gap set and checked, a new set of plug leads and a new set of plugs with the gaps checked and set.
The tappets were set from cold from cylinder 1 and then in reverse through to cylinder 4.
Rest of the engine assembled back in with a new fuel filter wich sits just below the fuel tank, battery charged fuel in turn the key a million times and nothing..............ok not to worry turn the distributor a little and hey he fired up but very very lumpy.........ok not a proplem i thought i'll just turn the distributor a little to get it somthing like ......nothing, its comes to that i can take number 3 and 4 plug lead off and nothing changes :evil:
i do know there is a spark as i fitted one of the old ones and held it against a bolt on the engine and it is definately firing.
I'm supposed to be going to Dubs at the castle in a few weeks but at this rate it looks very unlikey, if anyone has any advice then i would be most grateful
Thank you a VW marine caught in an ambush and low on ammo.
