I am in the process of doing exactly the same job and with the same challenges!!!
To get the water out of the sunroof tray, someone recommended to me that I look for some beetle rubber brake switch (or light I can't remember off the top of my head!) boots. Whilst they are round, they fit quite nicely into the triangular holes, and you can then seal them.
As for the six holes, I have connected them on each side, and they exit at the back and the front -front ones down the A pillar, and back ones down the bus (I am trying to get them out of the air scoops but drilling the hole is v. difficult.
I have a friend who is a cellar services engineer and using push fit connectors and t-pieces and flexible tubing, the water system on each side of the bus drains quite nicely.
The middle drain can go front or back, useful as when you are accelerating
the water view out the back.
I think the secret is to stop the water getting in in the first place, so have a rubber seal ( as per a modern sunroof) then have the drains as back up - not strictly OG but saves your headliner.
As for the ramps, Graham let me into that secret as well! I bought some 90 degree shelf supports from b&q and bent them so they lift the roof through the gap in the sunroof rails. They are then located on the two welds you will see in the drainage tray on each side.
Sounds easy, has been a PITA, but will (hopefully) work. Glad it is kept in a garage tho......
My headliner is out so if you want some pics, let me know.
Good luck.an then seal them.
Good luck.
