The interior panels inside are looking a bit worse for wear and am contemplating re-covering them myself - had a google and found some class video's from Chris at diyupholstery.com 8)
Here's one that I found very useful:
http://www.youtube.com/user/diyupholsterysupply#p/u/18/3UePeLp-Ngg
Inspired me to give it a go - I had the panel missing from inside the bootlid so thought that was a good test to see how I got on,
So bought some sand beige leatherette/vinyl from a german company - very happy with the quality, shipping took 6 days but that was over new years - tracking via GLS and parcelforce all the way which is nice:
https://www.atmlabel.com/
Here it is:
And bought 3mm ply panel from JK along with the silver push fittings needed - more on that at the end :roll:
Here's the board - laid out on the vinyl and roughly cut to size with enough to go over the edges:
Then used loctite spray adhesive that I had loafing around (it's for carpets e.t.c.) - spray both the board and back of vinyl with it and left 10 mins - then turned and sprayed where the vinyl will fold over:
Press them both together, start in the middle of each edge and fold over and still, with folded edges cut in (the vid above shows you how to do the edges
- hardest bit)
And voila - one completely covered board - surprised how quick it was to do:
Now - made small holes over the pre-drilled ones on the panel and pushed through the metal clips ready.......only to find out the holes in the panel don't match the mounting holes in my bootlid :shock:
doh! - drilled new holes in line with the bootlid holes and put in place for now - as it was a test to see if I could do it I'll take it on the chin and re-cover it again
- it's my fault for not checking, I just believed the bumf that said it was for my year van without doublechecking, knew it was going far too well
:roll:
Anyway - crap pic but here it is mounted in the van - finishes off the boot area nicely:
So after that I'm tempted to buy the rest of the interior panels (about £100 from JK - £80 iirc from a guy on ebay) and have a crack at doing the rest of the interior!
Anyone else done their own panels? Never worked with fabric before so it's all news to me! - would be easier to staple the covers but not sure if you can get small enough staples for 3mm ply
