Graham L said:The only reason I mentioned fitting shorter springs (and geeze is right on this) was I felt the current ones were a little too long compared with the damper body and believe a better ride/height combo could be achieved but have yet to try it. As I said I fitted 125lb springs to start with but feel the ride is better on 150lb springs.
I did try and offer these dampers nearly 18 months ago and no one would commit so its odd that this thread has raised so much debate so far down the line, perhaps I didnt shout loud enough at the time :? :? , I offered to lend my test set out and it was only Adam that ever took me up on that offer.
I'm happy to carry out some more testing and put more results up if it will help the EB communitybut Adam seems to be doing a good job.
Mark6455 said:i'd be interested but not sure which ones i would need
ive got wagonswest drop spindles 2.5 inch i think 4"narrowed beam and adjusters on both tubes which cant go any higher just lower :shock:
mark
67westy said:Mark6455 said:i'd be interested but not sure which ones i would need
mark
You may need a different size as the transporterhaus spindles are 3.5 inch. Best bet is to measure the distance between the shock mounts and compare it to other peoples to give you an idea
Mark6455 said:67westy said:Mark6455 said:i'd be interested but not sure which ones i would need
mark
Just checked with my mate who fitted them they are 3.5 inch drop so should be the same as yours
Ill keep checking this post for an update
Mark
sparkywig said:Just measure between the shock mounts and use that figure, as the new shocks will be about a 1/3 into their travel at this point.
mi2itsdl said:I am deffo getting a set of 16" shocks with 9" 150 lb springs. Probably in the New year. best get xmas out of the way.
dubdubz said:what options in term of length do we have on the springs - it sounds like the 150lb springs are a good option. And it also seems like the 16" length is preferred.
I have looked back through and probably missed it but are the dampers adjustable too?
And those that have bought - would you change anything or even not buy at all?
thanks
Darren
curly head said:If you run coil overs is there still a requirement for the beam leaf springs or do you remove them?
If leaf springs are left in do I remove the existing shock and drop the van back down to measure shock length? ie bolt mount distance
And help appreciated as I am fed up with the crap soft T2D shocks I currently have, the front of the van bounces everywhere, not good.
