mi2itsdl said:Went to order these and was asked is the hole required for the bolt 12mm, can anyone confirm please?
Good question. Do we have 12mm bolts?
Are you ordering drirect from GAZ, because I see that a few people have bought them now, but when I phoned up, they did not seem to be aware of this.
AndyO said:I installed these today:![]()
looking good, until:
Bindeage
Think im going to have to shave my nuts, i mean grind my bolts, i mean....well you know what I mean!
Geeze said:AndyO said:I installed these today:![]()
Bindeage
Looks to me like the shock isn't straight and just needs a spacer between the top bush and the beam tower?
Or is it just the angle of the photo? :?
AndyO said:VW (USA I think) did offer rear coilovers as an option, mainly for panel vans. There not needed, I would suggest you run with what you got, then if you still want them then measure the distance and order from GAZ perhaps. Money would be better spent on adjustable spring plates, again imho.
bobbyt said:Hi Mark, i was running transporterhaus dropped spindles and adjusters in beam near to there highest setting i could get. but with standard shocks was stilln a little bit low and the beam would scrape the floor alot and tyres wouls scrub the arches alot too,so fitted the T2d/gsf coilover shocks what a pain in the arse to fit because they were 2" too long so had to compress them to fit. were ok for a while then the bottom bushes fell to bits and one of the adjusters broke. Thaught i'd give them another go, i wish i hadn't bothered, this set was so soft it was like driving a strawbwerry jelly. I wish i had ordered the Gaz adjustable shocks two years ago! would have saved alot of time,effort and money. I am really happy with them. There is probably about 3" of adjustment in them for height, so i think the 16" shock with a 10" spring would suit most applications. (I am running 165 60 15 tyres standard width beam)
Regards Bob
Yorkieman said:AndyO said:VW (USA I think) did offer rear coilovers as an option, mainly for panel vans. There not needed, I would suggest you run with what you got, then if you still want them then measure the distance and order from GAZ perhaps. Money would be better spent on adjustable spring plates, again imho.
Thing is I don't have anything at present the shocks were shocking (sorry) and have been binned they were 18" extended and 12" open and am already looking at adjustable spring plates to lower the rear between 2-4". so do I just subtract say 3" from the measurements?
Geeze said:Yorkieman said:AndyO said:VW (USA I think) did offer rear coilovers as an option, mainly for panel vans. There not needed, I would suggest you run with what you got, then if you still want them then measure the distance and order from GAZ perhaps. Money would be better spent on adjustable spring plates, again imho.
Can't see that coilovers on the back is going to be worthwhile and there's the question of whether the stock damper mounting points are built strong enough to take the weight of the back (probably not :? ).
If it's a later bay (crossover on) then VW Heritage were doing HD torsion bars if you just want stiffer suspension out back, you can't use them on the earlier bays though as the splines are wrong.
Rear shocks depend on how much you lower it by. Measure it up at ride height, then look up the lengths of shocks to find the ones you need. But as a rough guide, if you don't cut more than one bump off the rear stops, then stock length is usually fine.![]()
