Opinion wanted.
I did the valves this morning for the second time I ring the run in period of a new 1786 engine. A few were a bit loose this time but I also noticed marks on the rocker case as of the rocker arm for one cylinder has been hitting it. It’s also a little noisy on that side I think.
Worth knowing js that I had to change the pushrod seal for that same cylinder after the first run as it had split. I have checked that the pushrod is seating properly on the valve and it looks good. Perhaps the pushrod is not properly seated on the cam though?
