Right....Just adjusted my coilovers to the highest setting, dropped the bus down and went for a quick spin. I only have one rub, when I drove down a speed hump at a higher speed than I would usually. So an improvement, but only me in the front, so need to test with a passenger. I measure the arch to tyre before and it was 2.25” and after 2.5”, so gained 0.25” (12.7mm).
Looking at tyres:-
Original bus tyres on steels:- 185 x 14 - 652 mm diameter
Current tyre size 185/65 15 (91) - 621mm minus 4.75% on diameter over std. = ~15mm increase in clearance over standard tyre.
So if I changed to 175/55 15 - 574mm minus 11.96% over std. but can’t find any greater than 77 load rating which is 412kg/tyre = ~ 25mm over my current tyre.
Found a 185/55 15 with a load rating of 86 which is 530kg, which I’m fairly sure would do. :idea: :?:
So going if I went for the tyre change option and having set the coil on max I would gain nearly 40mm of travel. This would certainly help, but at the expense of making the speedo further out than it already is. :|
So not sure which way to go at the moment, but there’s options open.
Whilst chatting to Steve (lhu128l) today, we may have a cunning plan………… :idea:
Looking at tyres:-
